ground wire question
- eyezpinned
car seems to be sensitive to electrical loads (especially cooling fan) in a ground wire kit setup, would i attempt to ground problem areas (like the fan) or does the kit that i've seen written up here ground everything?
93 rs: tokico struts & eibach springs, 15' rota gt3s, cf hood & gas lid, 2.5' exhaust w high-flow cat, tranny cooler, reupholstered seats, custom black interior, chrome miata handles, momo wheel & ebrake, spyder black projector lights w hid, altezzas, clear corners/sides, eclipse 8454 hu, diamond hex components w/ 3-way add-on & an re se 15' powered by 300/2v2 & 500/1 jl slash amps, corksport mazdaspeed bumper, euro mini sideskirts, fresh paint
- umcamara
Re: ground wire question
A faulty IAC (Idle Air Control) Valve could also be to blame.
- eyezpinned
i recently replaced the iac, the car would bog down bad when the compressor came on... it's not doing that... it idles up when i turn ac on, like it should. i should say i feel more of a pulse run through the car when the cooling fan kicks on but then the iac catches it... i'm trying to make that pulse more subtle... was wondering if a ground kit would help
Ground wires would help - but clean all the existing grounds first (take the nuts/bolts off and scrape the contacts to clean up paint/rust and put some dielectric stuff). Also check alternator and battery.
