24 Hours of Lemons
24 Hours of Lemons
Please see our post in wanted to buy - we are also looking for technical help. What kind of mechanical faiilures can we expect racing a basically stock V6 for 24 hours straight? Are there weak points that we shoould look out for?
Also, how does someone get special permission to post parts for sale on thsi forum.
Thanks in advance for everyone's help.
- TREVO123
if u do keep the fans wired on and pull the thermostat so it stays colder..
- mr1in6billion
You've obviously never been to the 24 hours of lemons. 100 degree heat outside, 300K miles on the odometer, burning through corners, bouncing off the redline, and those bucket still last the full 12 hours.Illa Killa wrote:And I dont think any car is built for racing 24 hours straight, you may have to work it internally to do that.
Strip the car. By strip I mean the cabin should have one seat and a steering wheel. Strip the engine bay. By strip I mean leave a bare engine and an ecu. Take the battery out while you're at it, that thing weighs a ton. The coolant overflow can be replaced with an empty water bottle. Forget wiring the fans, just pull them out (it's not like you'll be stopped anywhere), don't forget to pull the fan wiring (and all the other wiring in the car too). That hatch has to come off (according to the rules since it has glass). All your lights and bumpers need to go also.
G'luck
Thanks for the friendly advice. Actually a little more info was probably due on my part. Have raced Imporved Touring for years including 24 Hours of Nelson so I think we're fine on that part. What we don't know is what's prone to failure on MX3's.
For example, on my Fiesta I know a few things. Hubs are prone to breaking, outer 2 cylinders tend to run lean, oil pan requires baffling or starvation occurs, water pump cavitates at extended high rpms, motor mounts break which casues shifting problems as the linkage moves around etc etc etc
So, are their weak points on the MX3 V6. So far I've read posts about replacing timing chains (common to most vehicles) and water pump failures (glad I know about that ahead of time). What else should we look out for?
can you post some pics... I'm interested to see what it looks like!
Custommx3 - thanks for the advice, we'll look at changing the distributor before the race if we can fit it in within our $500 budget and if not, make sure we have the parts at the event.
Mooneggs - you can keep track of our build of the vehicle at http://www.formula-un.net - Just remember about half the site is tongue-in-cheek, the idea of this race is to have a ball, not beat the others into submission. At least that's our story and we're sticking to it. Plus, we've built our excuse for losing into the beginning.
In general, we see a pretty tough field. Although we feel great with our ride we've heard of 2 vehicles that will probably be class of the field. ! 91 Mirage with a 4G63 2.0L swap and an Achieva SCX with a 190HP Quad 4 (brutal fast but unrelaible)
- Tunes67
Just a follow up to the HEI mod.. its super cheap.. can be done for under $50 if you know where to get parts. Chev Chevette HEI module.. can even get these free out of a bone yard if you know a good one. Pretty much any 12v Coil. Though get one that is from a car that spins at least 8k RPM. And a MSD Power Tower. Your local race shop should have one for less than $10. And if done right.. is WAY more reliable than the stock distributor. The stock distributors are produced by Mitsubishi.. nuff said.
The alternators are also prone to failure.. slightly more often than you would expect from a car of higher mileage. Again.. produced by Mitsubishi.
The rear calipers on the GS model cars like to seize up. Again.. produced by Mitsubishi.
There are a couple of other minor things.. Timing belt tensioner.. they dont go bad very often.. but I have seen it.. dunno if I would bother tearing down to check it though in your shoes.
Valve cover gaskets.. these things are prone to leaking when they harden up. They like to leak oil into the spark plug holes which can cause the plug wires/plug to arc inside the hole. Not a lot of fun.
On higher mileage V6 engines, the PCV system practically pumps oil into the intake.. lots of folks run a custom "Catch Can" made up mostly from clear fuel filters (so they can see when to change them).
Tunes67
Tunes67
- mr1in6billion
- fieromx3
i wouldnt say cv joints are a weakness i find mine ot be quite durable.. had KL engine for over a year.. multi 5k clutch dumps wheel hop and alot more and they were work perfect still
ignitor (hei) is definitly a weakness though if u get the GM module make sure its grounded GOOD run a wire directly from the neg battery terminal to the hei module it self i had probs blowing them b4 and did this and works awsome now relibility has gone way up
also get a genuine GM module not a ''knock off'' where y get from napa.. i find the GM ones have better reliability
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
14.4 @ 96.7
14.5 @ 97.2
- Custommx3
- Site Administrator
He bought a car for $500, chances are hes not getting new CVs. @4 hours of driving will cause alot of heat..
Average 60mph in 24 hrs, thats over 1400 miles of constant wear and tear. It may not be top priority, but its something to consider.
Find someone local who has a CV warranty and swap them for free.. did I just say that?
Do the HEI mod, but do it RIGHT! take your time, cause if its not done right, it'll drive you nuts. Do it right, and you may gain a few ponies from having a weak OEM disty.
