kfze swap
Mnemonic
it has the same issues that the klze straight neck has it hits the brake resivour/booster, its a simple fix you just need to grab a millinia intake manifold. which in itself will be a nice upgrade as your increasing airflow by the larger IM and TB or you can use the k8 IM with the kfze TB but by doing so your restricting airflow. if you use the millinia IM with the TB it'll bolt right on without any problems, you can even use there fuel rails and injectors since its the same size, and the kf01 ecu wont have any issues
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
Well then how did Barry run his kfze(for 10 min.) with the kf15, then sold it to Hec who used it for months?Mnemonic wrote:kf15 uses a maf not a vaf, the kf15 ecu is the for the lantis type r version of the kfze (straight neck intake manifold square runners (doesnt fit in mx3) and kl31 cams) but it wont work with the je50 according to my buddies in malaysia the kf01 will run it just fine the ecu will adjust.
I am selling the motor this guy is talking about and i have the kf15 ecu to go with it, everything i have ever heard is that this is the correct ecu.
Mnemonic
my bad i misquoted myself, Flip that around
the kf01 doesnt work its the kf15 that is needed, i pulled mine and checked the code i had the wrong code listed, i retract my previous statement
hgallegos915
yah I used mine for months, actually it will still work when slapped on the k8.
kf15
kf15
-hec
Mnemonic
yea i always got the kf01s confused with the kf15s not sure why haha but i checked
Mnemonic
yea we did, ours went literally right around the same time, and our swaps happened right around the same time too. It's ashamed cause we raced to see who would be the 1st one with it done, and well we both lost haha
Mnemonic
if you want headers then just get the ss autochrome ones or obx of ebay for the mx6 probe, you'll just have to move your cat back some. but you can use the k8 exhaust manifolds and downpipe for now just need to plug the egr off which is easy, remove the bolt that the egr originally plugs in to, then get you a bolt and washer (i think 17 is the size) torque the hell of it into the inside of the bolt the egr originally plugs into (by inside i mean the bolts head should be inside the exhaust manifold) just torque the bolt into it'll go in with a little bit of manly force lol and will seal it to where you dont have an exhaust leak. Or you can go to home depot and find a bolt that actually fits it. i did mine the way i describe it for the simple fact i tons of bags of bolts.
hgallegos915
Just pretend you are dropping another k8 in there.. thats basically what it is, with a few lbs of torque. Pretend its a fresh k8. Direct swap if you use stock manifold and kf15 ecu. If you want headers its the same as if u had headers for the k8.
-hec
- 1992blazeredgs
Mnemonic
agreed, i always tell people k series motors (minus the kj) are plug and play1992blazeredgs wrote:As far as the swap goes, if you have never swapped anything in your mx3 before. Once you do, you will be amazed at how easy it really is.
Nate
