what engine have i got...?
just bought a japanese import az-3 4cyl says dohc on the engine but looks quite different to any ive seen on here the cam cover is black for a start and the plugs go straght in from the top anybody got any pics of what a standard jap mx3 should look like?
az-3
can you put up some pictures? that might help because i have never herd of that before
94 mazda mx3 rs 1.6l DOHC... probe 4-2-1 header, 2" catback, a spec CAI, advanced ignition timing, NGK plugs/ wires, obx light wight crank pulley
http://www.cardomain.com/ride/2754605/1
- atlantamx3
Yes- You have the B5 motor.
1.5L DOHC.
Anyway- Known to be robust little motors... they typicially put down power similar to the BP is my understanding.
1.5L DOHC.
although they left out the part where it was also in the AZ-3.wikipedia wrote: 1.5 L 1498 cc) B5 - (78x78.4 mm) - A Japanese-only variant of the B5 with fuel injection and revised head/intake system. Found in the 1989-1994 Mazda Familia Interplay and Ford Laser S. Power output 81 kW (110 PS) at 6500 rpm and 12.9 kgf·m (127 N·m) at 5500 rpm.
http://www.carsurvey.org/review_40361.html
check that out, its a review on the AZ-3 engine. hope that helps
- atlantamx3
this has info about your car... and what options it has
http://www.cars-directory.net/specs/mazda/autozam_az-3/
holy smokes I was just looking at the 1996 one and it shows k8-ze and b5-ze... why would they be followed by ze??
- Tunes67
Mazda's ZE engines were basically the same as the DE engines. The only real differences in most cases were higher compression pistons and slightly more aggressive cams. The reason you see so many ZE type engines overseas is because they have higher octane gas available to them that we dont have access to here in the US. So you can thank our government for taking away the fun engines
Tunes67
Tunes67
cars been playing up recently , it wouldnt start at all one day just turned over but i eventually got it going by turning the key and pumping the accelerator and now it just doesnt idle right it idles pretty low about 500 id say then it wil dip and shoot up and down and settle again at 500 , also when driving along and if you give it very gentle acceleration sometimes it just dies for less than a second just a little blip this is weird
az-3
