pissed off
- xboxlivemonkey
pissed off
ok well i took the car to the mechanic
he had it for a f---ing week
and still has no clue at to whats wrong with my car
ok so far he tells me its not the timing belt
since the car is turning on without a problem
so he tells me
its hte gas tank pump
the cars symptoms are
when i turn it stalls , my rpms drop all the way then go up and accel normal
also this happens radomly if it gets real bad when i revers mainly to drive out it will drop and shut off
its been over 3 weeks since iv been able to drive my babe , and the mechanic is dooing nothing , i will be taking it to another one but id rather
look for the problem myself
-_-
im pissed of also he changed my oil filter without my permission and we know how thats gonna end up like
lol
any way
i need help a.s.a.p
^_^ thanks
so he tells me
-_-
lol
any way
i need help a.s.a.p
^_^ thanks
- Custommx3
- Site Administrator
I had a similar issue, turns out when my gas level was low, crud in the bottom of my tank would get sucked up on my fuel pump screen and stall ou tthe car. If I had a full tank I had no issues. I cant say thats your issue, but I can say pull your pump and look in your tank.
ALSO, NO CURSING IN POSTS.
				IRISHmx-3
- xboxlivemonkey
[quote="Custommx3"]I had a similar issue, turns out when my gas level was low, crud in the bottom of my tank would get sucked up on my fuel pump screen and stall ou tthe car. If I had a full tank I had no issues. I cant say thats your issue, but I can say pull your pump and look in your tank.
ALSO, NO CURSING IN POSTS.[/quote]
sorry about cursing
the mechanic said that the cause was th fuel pump
so he is charging me 300 since i do not know how to do that
its better then most mechanics are willing to charge me
so we will see later on today whats the result
sorry about cursing
- xboxlivemonkey
[quote="Custommx3"]dude, you can get a FP cheap and do it yoruself.
Its under the back seat! :)[/quote]
i know but i dont have much knowledge and id rather have him do it and have my car now since its been almost 3 weeks since i used my car =(
im looking for a repair manule for the car
im also looking for a nother mx3 which i actually found on for 1,500 v6 but i dont no how many miles , i hope my g-f buys it lol so i can use hers and experiemtn with my car
- Tunes67
No doubt..  wish you lived closer to me..  I'd only charge you $200 for the job.
Tunes67
							Tunes67
"So long..  and thanks for all the fish!"    "Momma says VW Bugs are the devil"     "This one time at band camp..  I stuck a flute in my Throttle Body"
id replace it for free...i put a walbro in my car and i i wouldnt have played arround with the care the whole time it would have probly taken thirty mins at MOST
check your idle air controol... they tend to have issues on the b6...not much you can do because of price but you can clean it....
 1994 MX-3 1.6L B6DE 16v DOHC - rear disc swap, nix power steering/ac, Corksport f&r strut tower bars, Pedders urethane control arm bushings, urethane motor mounts, steel braided brake lines,  painted dash, protege tranny
90 Miata w/ b6, Konig Lightspeed rims, Cams (boost to come soon)
74 Porsche 914 w/ 1.8L - restoration prooject
- xboxlivemonkey
- xboxlivemonkey
AND ......DONE
well the mechanic changed the fuel pump and ikt fixed the problem , the car is working good , im going to do a lube job soon ......dont no when but i need to add some restore , my engine has the grainy sand noise = /
im also thinking of cleaning the injectors
thanks for all your help guys
also he said my car is a 1.8L , but the i4 is a 1.6L ,its a 94 mx3 incase you guys forgot ( doubt it )
can some one clear that up , i almost got into an argument but i stayed shut since he was fixing my car lol
performance wise , ................any suggestions ^_^ thanks again guys
				mortenmorfar
Re: pissed off
There is only a 1.6 4cyl engine for the MX-3, if it's a 1.8 4cyl, the engine have been swaped
maybe it's a 1.8 V6 you have ?
- xboxlivemonkey
