Can I put a GS lip on an RS
is this possible, looking at the front GS lip because it looks so much cleaner and is not as expensive as a body kit.
95 RS Blaze Red, RTX 17's Gunmetal with Polished Lip, Falken Tires, GS Lip, Carbon Fibre Altezza Tailights, Black and Red Interior (front/rear seats, door panels, and rear panels. GS Spoiler, Hood with scoop, Black Mirrors, Pioneer Deh-p6800 Deck, Infinity 6010cs components, infintity 4x6 Rears, Red Shift Boot , 12 Blue Interior Lights throughout car and 4 leds in vents wired to 2 switches total
http://www.mx-3.com/phpbb2/viewtopic.php?t=54606
http://www.cardomain.com/ride/2394622
- PATDIESEL
WHAT. Neutral, if it is that easy for you please come over and do mine. You have to drill holes in the RS bumper that are unmarked and very hard to mark correctly. The easiest way I see to do it is to paint the bolt ends on the lip and then carefully place the lip on the bumper. The paint will mark the holes and then you drill them. Then after a few test fits and most likely boring a few holes larger to compensate for poor placement it should fit.
- atlantamx3
- neutral
Ugh, that sounds like a pita. Maybe I just lucked out? Bumper on my 95RS already had those holes. I guess it's possible one of the previous owners had the bumper replaced and that a GS type bumper (minus lip) was put on the car. Sorry for any bad info. I just assumed that all RS bumpers were predrilled...PATDIESEL wrote:WHAT. Neutral, if it is that easy for you please come over and do mine. You have to drill holes in the RS bumper that are unmarked and very hard to mark correctly. The easiest way I see to do it is to paint the bolt ends on the lip and then carefully place the lip on the bumper. The paint will mark the holes and then you drill them. Then after a few test fits and most likely boring a few holes larger to compensate for poor placement it should fit.
hahaha ive done this..i found a gs and the lip was broken...i got it for real cheap at the junkyard and ended up molding it to my bumper and cutting the middle out to for a "vaderish" look to it.check it out..its a pic on my tunerfriends site.
http://www.tunerfriends.com/forums/dima ... 13922&1026
live life a quarter mile at a time.
life is about learning from your mistakes and not regreting them.
