Solution to foggy head lamps
I BOUGHT THIS PRODUCT FROM ADVANCE AUTO PARTS FOR TWENTY BUCKS AND IT IS WELL WORTH IT. TOOK ME 30 MINUTES TO HAVE MY HEADLAMPS LOOKING LIKE NEW. CHECK OUT THE SITE :
http://www.crystalviewchemicals.com
IF LIFE DOESN'T OFFER A GAME WORTH PLAYING, THEN INVENT ONE.
dont worry your head lights will go back to the crapy look it was. I get this nice little bottle called plastic x at k-mart every time I wash my car I put this on my head lights and it will stay like new for ever now. bottle will last you for a long time to.
1994 Mazda MX-3 KL-ZE
Lookwuticando
JapesMooney
Oven baked lights?
Err sorry... Oven baking the inside? This can't be what it sounds like. I'd love for you to expound.
95 MX-3 1.6L 4 Cyl B6 DOHC
- jschrauwen
Re: Oven baked lights?
Once again, it's covered in the stickies and FAQ's.JapesMooney wrote:Err sorry... Oven baking the inside? This can't be what it sounds like. I'd love for you to expound.
Oven baking for the purpose of removing the lenses safely. Part of a process normally, as a prelude to gutting the inards in preparation for modding for projectors. The inside lense must be free of any ribbed portions that will taint the effectiveness of the future projectors. Others feel it necessary to remove the lense to clean the inside of it.
There's numerous products out there that will do the job of removing the hazing on the exterior of the lights. For over eleven years I've stuck with using Mother's wax remover/cleaner. I give them a good cleaning/polishing 2 or 3 times a year and they've remained good as new. One of the headlights on the 95 GS that I picked up this past fall had severe hazing (the other had been replaced with a new one by previous owner). By using that wax cleaner, you can't tell the difference between the original and the new unit. A little time and a lot of elbow grease and good as new.
If someone has fogging on the inside of the lense, then it's best to verify that the 90 degree rubber elbows (used for venting purposes) on the back of the light unit are clear of any debris and the openning is facing downward.
Lookwuticando
- solo_ryder
- jschrauwen
I'm aware of that and do know what you mean. Normally, and I mean normally, the reflective lenses should never really need to be cleaned unless the venting or seals have been compromised in the past. If it has, than there probably isn't really much of an alternative but to get inside.Lookwuticando wrote:To clean the mirror chrome part inside, the lenses have to come off. The only way this is possible is with heat, they are glued together. Know what I mean?
E-Spec / J-Spec lights. Yep, got me the J-Spec ones. Certain E-Spec units were glass though.solo_ryder wrote:Here is my solution for foggy lights
you don't really need to clean the inside tho.. just cleaning the outside with a good plastic wax ( i use plastix by mgwire) should take about 10 mins to give you close to factory clean headlights.. i don't understand why somebody would go through the hassle of baking their headlights if they could get great results with a 10 mins buffing job.
Lookwuticando
- mitmaks
GS 27 works great too
- Tunes67
Ok.. here is a old hotrodder trick for cleaning inside light assemblies that are sealed.. take 1 large 5 gallon bucket.. fill with water. Place light assemblies inside bucket.. submersing completely.. dump in 25 tablets of efferdent. Let sit over night. Rinse and dry. This little trick worked so well I had people thinking I had bought new assemblies for my old nova. You can scale this down of course and it would probably help to put some tablets directly inside the housings (assemblies) before submersing them.
Tunes67
Tunes67
Lookwuticando
