-So do I run striped (gauge) wire to striped (dimmer) wire and black (gauge) wire to black (dimmer) wire?
-Or do I run striped (gauge) wire to red (dimmer) wire and Black (gauge) wire to striped (dimmer) wire.
-Or do I run striped (gauge) wire to red (dimmer) wire and Black (gauge) wire to Black (dimmer) wire.
-Or do I run striped (gauge) wire to striped (dimmer) wire and Black (gauge) wire to black (dimmer) wire.
---Red/Black Wire---
[ Dimmer ] -------Red Wire-------
-------Black Wire-----
_____________________________________________
------Black/White Wire------
[ Gauge ]
-------Black Wire------------
Sorry for the stupid question im just confused and Pissed cause I broke the Temp Needle and the needle set pin is stuck inside the Cluster
Thanks in advance for the help.....
PS...finally found a spare Sunroof switch to replace my broken one....Yeaaaaaaahsssssssss (and now I have to go out and find a used Fuel/Temp gauge)
