Hey guys, new to the forum and having searched for the answer I cant find it! Just want to know if this is a common problem or not.
Right hand drive passenger side rear footwell keeps getting wet, and when I say wet, I mean soaked. Sometimes after its rained, sometimes after I wash my car.. doesn't seam to be every time though. Any tips would be helpful...my carpet is rotting away!!!
Wet Passenger side Foot Well
- PATDIESEL
It could also be the bottom of the drain tube has been knocked loose. The drain ends in the passanger footwell and if kicked it will pop inside the car instead of draining out the bottom of the chasis. It is a clear tube with a black rubber gromet on the end on the right side of the footwell just under the dash. It is not too hard to find if it was knocked loose. You have to take the plastce trim piece off to see it though.
take out the back seats and carpet. You'll get a better idea then. Also possibly the seal on your hatch? could be worth a try also
check my car domain
http://www.cardomain.com/ride/2144443
door rubber
Does anyone know of where i could locate some new door, and hatch rubber? the ones that are on my car just sort of hang there and im not happy with the water leaks.
Pa.MazdaMan
