spacers/thermal spacers-momo adapter
Curoius about the spacers.....would i need to remove the front strut bar if i use the spacers on the kl-ze?  Also curoius about momo steering wheel conversion....what product # is the proper adapter?
						- PATDIESEL
The real queastion is which intake are you using on the ZE.
If you have the Millinea then no it won't fit, if you have the curved neck I don't think it will fit either. Only the straight neck will fit with phenolics and a strut bar. that I know of...
- Yoda
The strut bar hasn't been made under the Fast brand name in about 7 or 8 years. Now you see it under the names Vibrant, Ractive, Racespex, Extremevision and others but they are all made in the same factory in Taiwan.
						gsr-se wrote:I got the front and rear strutbar from corksport when it was in Oregon still..... I keep thinking of the brand " FAST", but unsure.... I'll take a peek @ Corksport again and see...
- PATDIESEL
I think so, but if not it is only a little too high. Just bend the strut bar or the mounting points a tad and it will be fine. You need about 1/4" of room between the engine and bar. (assuming that the motor mounts are all in good condition, not 10 years old or torn)
