CV Axle
- SnoSurferr
CV Axle
Dam*it I can't get my CV axle out..... Ive tryed everything, Ive had it out before but now It doesn't seem to wanna come out. Anyone have some Tips ????? Its the driver's side axle im trying for. Any help would be great
- Limegreen mx-3
Use 2 crowbars one up top one on the bottom pull at the same time thats how i got my stubbering CV axle out it can be a B!tch though.
- ryanlindenberg
i put a crowbar on one side and hit the other side with a hammer...out of my entire engine swap CV axles were the biggest pain.
CARDOMAIN WITH UPDATED PICS
mitsudriver
I pulled mine by tieing two ropes behind the joint closest to the transaxle and running one around the right side and one around the left side of the joint, tieing them to a bar and jerking. Oh so rigged but it did work. This of course was after spending a couple of hours cutting the axle bolts off the end with a dremel....
- Shades
I actually did my on Saturday... I did what limegreen MX-3 did.
Take the battery out and the tray it sits in... slide a crowbar or screwdriver from the top. Get someone to crawl underneath and do the same... give it the 1, 2, 3, PUSH!
"Do it ONCE, do it RIGHT!"
- SnoSurferr
