Shaving Antena
Car Stereo/Alarm Discussions
Bochek
Shaving Antena
Post by Bochek »
So i figgured i might shave my antena while im doing some body work.
My question is, what do you do so that you can still get radio reception, i bairly get any signal with the antena down.
Any ideas would be appreciated
Bochek
JYOUNYA1
Post by JYOUNYA1 »
Do an online search (ebay, nopi.com.....) you can purchase a hide-a-way antenna...it comes in a roll of tape in which the antenna is stuck too...you tape it inside around the outer most part of your windshield were it cannot be seen...I cannot remember if it directly plugs in to your radio, or if it goes to some sort of modulator that you tuck away then to your radio....I was like 13 years old helping my brother put on in his porsche, and it worked perfectly...after installed you could not find a trace of antenna unless you started taking things apart. I know I recently saw one in Advanced Auto Parts.
~Jay
93 MX-3 GS 1.8 Liter V6 Teal Mods: Pace (Maker) Setter Custom Catback/ Phantom Auto Meters: Voltage/ Water temp, Air/Fuel (in which not one gauge except voltage works) / Custom piece of s*** intake / 17" RacingHart Z5000 wrap in Khumos that are dry rotten / Altezza Tail lamps/ Custom Black interior (still in the works)/reverse indiglo gauges/ Push Button Starter/ Viper alarm with Proximity sensor/ Brembo slotted and dimpled rotors/ rear hatch shade/ Pioneer Premier DEH-840MP, ,2 custome fitted 6"inch pioneer door speakers, 1 Pioneer Premier 200 watt amp
Bochek
Post by Bochek »
thanks, will keep it in mind, it would be a good time to do it seeing as i have the front window out and in the middle of doing body work.
Bochek
Return to “Car Stereo/Alarm”
