Engine rocks back and forth
I just noted that my engine rocks back and forth when I change gears ...I think something thats keeping it in place might have broken which could be the reason the car shakes quite a bit when the engine is running. Anybody know what might be broken and if I should have it checked out?
1995 Mazda MX-3 RS
How cheap?! , Puerto Rico ..long ways away. Mine is 4 cylindersJoey's mx wrote:Well i would chage them..it might be harder on the axels and you will lose some torque. because the engine is moving more then it should be!!!
Where do you live and what engine do you have...i have some extra mounts for cheap!!!
1995 Mazda MX-3 RS
94 Mx-3 Precidia
mitsudriver
