Engine rocks back and forth
Angel
Post by Angel »
I just noted that my engine rocks back and forth when I change gears ...I think something thats keeping it in place might have broken which could be the reason the car shakes quite a bit when the engine is running. Anybody know what might be broken and if I should have it checked out?
1995 Mazda MX-3 RS
Joey's mx
Post by Joey's mx »
worn or broke motor mounts!! The engine should move alittle when it shifts gears or you give it gas!!!!
Angel
Post by Angel »
Joey's mx wrote:worn or broke motor mounts!! The engine should move alittle when it shifts gears or you give it gas!!!!
Thanks joey, thats it ...should I worry about it? I think one in the front is broken and one in the backside is cracked.
1995 Mazda MX-3 RS
Joey's mx
Post by Joey's mx »
Well i would chage them..it might be harder on the axels and you will lose some torque. because the engine is moving more then it should be!!!
Where do you live and what engine do you have...i have some extra mounts for cheap!!!
Angel
Post by Angel »
Joey's mx wrote:Well i would chage them..it might be harder on the axels and you will lose some torque. because the engine is moving more then it should be!!!
How cheap?! , Puerto Rico ..long ways away. Mine is 4 cylinders
1995 Mazda MX-3 RS
ariesdude
Post by ariesdude »
94 Mx-3 Precidia
mitsudriver
Post by mitsudriver »
You can check to see if anyone makes solid steel mounts. I have some in my 3000GT VR4 and they're great. No engine movement at all.
azazel95
Post by azazel95 »
Make sure they're not just loose. Mine were loose and I bought new mounts with out realizing it. Luckily it was the wrong mount so I didn't instal it before seeing the bolt on the mount was just loose.
