TEMURATURE GAUGE PROBLEMS PLEAS HELP
J_BOYLE
Post by J_BOYLE »
when im driving and i hit about 3 thousand rpm my temp needle drops to cold and the goes back to normal wne i let off the gas or shift gears does any one know what the problem is i have already changed my thermastat please help
thanks in advance
Bochek
Post by Bochek »
WHY ARE YOU YELLING?
actually, i dont know why it would do that, but my guess would be a bad connection somewhere. probably going into the water temp sensor, located in the thermostat housing. or it could be the sensor its self
Bochek
jimishadow
Post by jimishadow »
chec the connection where wire plugs to sending unit.. something is making poor contact
Custommx3
Site Administrator
Post by Custommx3 »
ryanlindenberg
Post by ryanlindenberg »
still could be a bad thermostat, or like stated above could be the sending unit or connection.
i replaced my thermostat in my escort GT twice before it worked. i also had to replace the thermostat in my MX3. it is a common thing to fail and sometimes are defective right out of the box, good thing they are easy to replace (at least when it isn't really cold outside).
CARDOMAIN WITH UPDATED PICS
