ENGINE SWAP NEWBIE QUESTION
ccmextreme
Post by ccmextreme »
I have a 95 mx3 with the 1.8 v6
can i get a engien from a probe gt (2.5L V6) and swap that it ?? if so is it a basic take out old put in new engine or will there br problems with the engine mounts ?
Custommx3
Site Administrator
Post by Custommx3 »
read the FAQ.
Selecta
Post by Selecta »
Friends are just enemies who lack the testicular fortitude to kill you.
I'm a 2min man in a 1min universe
94 GS - KLZE, Spec2 Clutch, Fidanza 9lbs FW, 2 1/4 full magnaflow exhaust. 145WHP / 147WTQ
babyblueMX3
Post by babyblueMX3 »
yes, yes, no
RIP 400whp ZE-T MX-3
PATDIESEL
Post by PATDIESEL »
Just make sure and get a OBDII Probe motor and you'll be ok. Read the FAQ and search for other swap pages also. The more you read the less chance you have of messing up and the less time it will take you.
I have a complicated write-up here: http://www.atlatnamx3.com/mocaforum look under the ZE swap page.
deathman
Post by deathman »
it's a straight bolt in, but you have to exstend a couple wires. if i remeber right went i did mine i had a differant rear exh. manifold, go with headers, you will need the maf from the new motor, it would also be best to get the ecu, not sure about the obd2 stuff never had the mess with yet.
