new v6
new v6
Hi peeps I have just bought a 1993 V6 MX-3 (jap import) first things first, what an awesome engine, the noise as it hits 7500rpm has to be heard........just a few questions, does the jap import differ from the regular UK models, besides having air con as standard. And wht is VRIS, i have tried a search but come up with nothing??
cheers guys
cheers guys
First time i heard that v6 scream upto 7500rpm.............i think i wet myself
cheers for the quick reply, what does vris stand for? as soon as you hit 4000rpm, esprcially with a cold air induction kit, the engine goes nuts and really flies. Shame there arent many performance parts out there for these cars
I believe it's actually 135hp...The K8's here redline at 7000rpms,
Im having my car dyno tested this weekend so will be able to tell u all how much it is putting out, although it is fitted with a stainless steel exhaust and induction kit, so will prob be slightly higher than stock, any ideas why the jap model produces more power? it surely cant just be due to the higher rev limit can it???
thanks for the explanation, if thats the case then it isnt like the honda Vtec system which changes camshafts at higher revs for more power? does anyone have definitive performance figures? i have seen so many differnt figures for these cars i dont know what to believe????????????
Right. It gives a similar effect on a dyno as VTEC, but a completely different method. If you've ever seen a dyno graph for any of the Mazda V6 engines, you'll see a pretty damned flat torque from about 3,000 RPM up. That's the VRIS working.swanseav6 wrote:thanks for the explanation, if thats the case then it isnt like the honda Vtec system which changes camshafts at higher revs for more power? does anyone have definitive performance figures? i have seen so many differnt figures for these cars i dont know what to believe????????????
- PATDIESEL
Not higher compression, just no EGR...
Love the KL series motors (althought the stock GS motor is a K8 not a KL, they are still basicaly the same) Masterfully designed and killer performance for a early 90s engine. There are plenty of mods for the motors if you swap over to a KL series. KLs came in Ford Probes, Mazda MX-6, Millinea, or 626s. You can get fully built valve trains, better rods, any compression piston, headers (also any Kl header wil fit the K8), intake manifolds, lightweight flywheel pullies (also a Kl pulley will fit a K8) and tons of other stuff. Enjoy, thay are great cars
