Does anyone know of a company that makes a header for the SOHC 1.6? I know Corksport has the genie header, but I asked them about it and all they said was that they've never tested it because it's not their part.. but from the looks of it, it looks kind of shabby. :/ Well at least not worth that much money, but maybe I'm wrong?
Also, are there any headers out there availible that sorta match up to the exhaust ports on my motor? I can port the header to match up as long as it's close..
Thanks.
-josh
B6-ME... Headers' ?!
1992 MX-3 SOHC 1.6
15" 5 spoke star wheels with 195x50 Futura sport tires. Solid filled Poly Urethane motor mounts. Short throw shifter, aluminum and carbon fiber shift knob. Ebay Cold Air Intake, 2" Custom Cat Back exhaust with Glass pack muffler and 3" slant chrome tip. Dual 10" JBL's with Kenwood amp with neon pulsating light, dual 6x9's in carpeted box, Clarion head unit. Custom blue/black interior.
- neutral
Lotta LOTTA talk on this topic over the years but from what I've read, only one available is by http://www.marcor-genie.com./geniepricing.htm which is the same one sold by corksport.
-Jim- Josh
yep thats the only one in production. what the most common thing to do is to buy a ford probe header and cut off the flang and weld on a new one to match up with the B6 block.
- papa roached
or you can just get a gasket and dril the mounting holes onto the flange and a small amount of porting on the outside edges to make it line up
BUMP!
I don't think the DOHC exhaus ports are even close to the same alignment as the SOHC, so I don't think the probe 2.0 header will work for the SOHC, but I could definitely be wrong.
Help anyone?
Help anyone?
1992 MX-3 SOHC 1.6
