6ft, 287 lbs last time i checked, car still fast with a KL-ZE and my big mass in it
<small>[ December 02, 2004, 11:09 PM: Message edited by: papa roached ]</small>
Parts needing installed: turbo kit from BB (if i ever get it), 9.0:1 CR Diamond pistons, 4340 forged H beam rods, C/J-Spec spoiler, Nissan red tops in KL rails http://www.cardomain.com/id/blazejeremy
Originally posted by jplar: I'm clocking in at 310 lbs. Heck, I'm losing 6 hp just by sittin in my car.
LOL!! Not to start any bragging or anything but anyone here into weight lifting?? If so what are your maxes on the four core lifts?
Deadlifts 400lbs
Bench 310lbs
Squat 300lbs
Back it varies depending on what exercise i do but pull downs around 250 max (feels uncomfortable in my shoulders if i do more)
Yeah I know JWMX3!! I'd never had images hosted before so I was all screwed up on what to do. Its alot more fun to look at in real life than threw a little picture. Its so fun doing such a huge modification to the looks of your car. And i'm just really proud of it!
THIS USER HAS BEEN BANNED, DO NOT DEAL WITH HIM. - MX-3.com Admin
its's been awhile so lets get this going again , it seems as though alot of the pictures do not appear since the new site went up ...maybe a moderator will take note and fix this
