need an idea for a plug
- monty73741
i am adding a war drive kit to my car.....
i need to add the three inputs for video monitor, & two for sound
does anyone have an idea what to do i woul like to just have sone type of plugs, like built in...or something...
any ideas
any ideas
Jason Danaher
Please Help Support MX-3.com
What make/model deck do you have?
basically war driving is driving around looking for open wireless networks, which is commonly done using a laptop computer, a wireless card with an external/more powerful antenna, and the netstumbler.com software. It can also be done using a CarPC type system (like myself...i've wardriven a few times), which i belive is what monty is trying to do
War driving evolved from the term "war dialing", which was to randomly dial phone numbers with your computer modem and see if you could find a computer on the other end. War dialing got it's game when the main character from the movie "War Games" (1983) used that technique to (accidentally) find a miliary computer.
- monty73741
i have the plug for the head unit...but i want to kinda make a built in plug like the back of a home stereo...llike a yellow, red & white plug...build in the dash so if i want to hook up my lap top, i pod, etc etc all i need is a cable
Jason Danaher
- Custommx3
- Site Administrator
In this case, you can use a video switch box, and just get a audio splitter.
problem is, your going to get audio from all sources @ once if they are turned on.
Are you using a car PC?
My car PC has audio comming from the C sraight to an amp. If your using a PC, you can use the Line in as a audio input as well as the Mic could probably be used as an audio input.
- monty73741
tunes 67 why have wireless if you arnt gonna broad cast...u can always use wep encrytion
jason
jason
Jason Danaher
- Tunes67
Doesnt have to broadcast to be wireless.. The wireless card in my laptop sends the signal to my wireless router.. its then authenticated via WEP and MAC address. If you allow your wireless router to broadcast even with WEP or MAC address lock downs.. you are still allowing "War Drivers" to see that you have a wireless network at all.
Tunes67
Tunes67
- monty73741
yeah yeah there are still hackers out there that can see ur wireless.........honestly i use 256bit encyryption so if they hack that they deserve to get into my system lol
Jason Danaher
