FAQ: General Engine/Forum Terms. READ IT!!!!!
Locked
ASHTRAY75
Post by ASHTRAY75 »
Ok, Im the new owner of a 92 1.8 v6 mx3. I need to know what model number it's called... the motor that is. Any nicknames.... Im just trying to follow you guys on this board. And Im not familiar with the verbage and lingo just yet. Definitely will help when it comes time to purchase parts from other owners. Thanks in advance.
Custommx3
Site Administrator
Re: need to know some info on my mx3 guys
Post by Custommx3 »
North American models with K-series Engines:
*V6 Engine Codes*
K8 1.8 liter (1844cc) 130Hp :92-94 Mazda MX-3 GS (US-spec), Precedia (CDN-spec)
k8-ZE JDM version of the k8DE - 140 Hp.
KF 2.0 liter (1995cc) 160-170 Depending on Model
KJ (KJ-ZEM) 2.3 liter (2254cc) :95-02 Millenia S
KL 2.5 liter (2497cc and 2507cc) :93-97 Ford Probe GT, Mazda MX6 LS, 95-02 Millenia, 93-02 626 ES (sometimes referred as KL03 or KLDE)
KL-ZE JDM version of the KL-DE (190-200HP)
*I4 Engine Codes*
B6-SOHC 1.6L Base engine for 92-93 RS models 88HP
B6-DOHC 1.6L Base engine for 94+ RS models 105HP
B6t 1.6L 136hp turbo engine fitting RS models
BP 1.8L usually found in Ford Escorts, Mercury Tracers, Kia Sephias, and Mazda Proteges.
BPT 1.8L 210hp/185HP (depending on model) turbo engine fitting RS models
*Common Terms*
The suffix meanings are as follows:
"E" stands for "Electronic Fuel Injection" (EFI)
"D" indicates that the engine is a dual overhead camshaft model
"Z" indicates that the engine is a Mazda performance version. For the K-Series engines, Mazda adds higher compression pistons, more agressive camshafts and larger ports in the heads and intake manifold.
"M" indicates that the engine is a "Miller-Cycle" engine which utilizes a screw-type supercharger and dual intercoolers to charge the incoming air, boosting its output.
DOHC - Dual Over-Head Cam
SOHC - Single Over-Head Cam
Precidia = Candian release name of MX-3
FI - mean Forced Induction; Nitrous Oxide (NO2 or NOS), SuperCharged, TurboCharged
IM - Intake Manifold
TPS - Throttle Position Sensor
WOT - Wide Open Throttle
CEL - Check Engine Light
ECU - the car's computer (engine control unit)
ATCM - Automatic Transmission Control Module
OBDI/OBBII - (On Board Diagnostics version 1 or 2) refering to the type of ECU, OBDII has alot more diagnostics. Unless your Mx-3 GS is made in 1996+, it will be OBDI
AT/ATX - Automatic Transmission
MT/MTX - Manual Gearbox
LSD - Limited Slip Differential
CAI - Cold Air Intake
lakersfan1
Post by lakersfan1 »
Originally posted by Tempus:
The -ZE suffix engines are typically from Japan. (I'm not sure what was used in european markets)
All Euro spec are DE also. They even have a DE version of the 2.0L KF engine, which we never had in the states. I believe alot of European countries have tax breaks (or lower taxes rather)for cars with under 2,000 cc engines, so pretty much every car sold has some kind of 2.0 liter option, including alot of BMW and Mercedes.
Locked
