Problems with the bolt on turbo
Okay I know these are all tuning problems, but I need a little help trying to figure out which ways to handle them.<P>First Problem: Since the turbo project the car idles up and down and then sometimes dies.<P>Second Problem: Since I added the Apexi S-AFC now when I am going down the road and just crusing (not pushing any boost) the check engine light comes on. Then when I accelerate it goes back off.<P>I have tried adjusting the idle with no success, maybe I am not persistent enough.<P>Any help would be appreciated.
94 Mazda MX-3 BPT Custom Intake/Exhaust T3/T4, 51mm BOV, Tial WG, 2.5" Piping, 880cc Inj, Godspeed Intercooler, TEC II
My MX-3 Website
My MX-3 Website
- cjthor
Re: Problems with the bolt on turbo
First Problem: Since the turbo project the car idles up and down and then sometimes dies.<P>Second Problem: Since I added the Apexi S-AFC now when I am going down the road and just crusing (not pushing any boost) the check engine light comes on. Then when I accelerate it goes back off.<P>Hey there,<BR> I am having the same prob with my afc.. Idle goin up and down. What sensor number are you using? hw11? Let me know. Maybe we can figure this out.
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
I am running it with FL8. Do you think this making the difference?
My MX-3 Website
My MX-3 Website
it could be. we(94+) have a hotwire maf so we need the "hw" sensor #'s.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
Something else to check is if you have any leaks in your i/c pipes. I haven't had any problems with the s-afc causing poor idle. Mine worked just fine for the 2 days that I had it installed before the motor decided to go south on me. If you have the '92-93 with the S-AFC, try fl8. If you are running the larger fc3s maf, also try fl5-7.
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
Since we have the hot wire MAF what number should we use, According to Apexi's instructions the B6 Familia type uses the FL8, so I don't know.
My MX-3 Website
My MX-3 Website
- cjthor
Nobody has been able to help me with the settings either. You just have to start with HW1 and go thru all of em to see if they work. What wire did you splice into for the MAF wire? was it 2O? Oh and dont even bother callin Apexi... They are NO help. Only use the hw settings...
Jarid Perry
This is how I hooked mine up.<BR>I used the wiring diagrams, ECU Electrical Specs, and the Wiring Diagram on the Apexi<P><BR>Apexi Wire---------ECU Terminal--------Color<BR>Red Wire Power------1B-------------WHT/RED<BR>Gray Wire Throttle---1N-------------RED/WHT<BR>BROWN WIRE GROUND----2C----------BLK/LT GRN<BR>BLACK WIRE GROUND----2C----------BLK/LT GRN<BR>YELLOW WIRE MAF------2O----------LT GRN/BLK<BR>WHITE WIRE MAF-------2O----------LT GRN/BLK<P>GREEN WIRE RPM SIGNAL USED YEL/BLU WIRE OFF TACH BEHIND INSTRUMENT CLUSTER.<P><B>MINE SEEMS TO BE WORKING PROPERLY, BUT I AM NO MECHANIC.</B><p>[ June 09, 2002: Message edited by: Kick @#$ Mazda ]
My MX-3 Website
My MX-3 Website
Okay I changed those settings (HW-11) and for the most part it runs good, but on deceleration I still have problems to fine tune the dec-Air setting, can someone explains this part to me because the manual is worthless.
My MX-3 Website
My MX-3 Website
I don't know what the deal is with this thing, Now when boost release it pratically dies it seems like it is getting way to much fuel and bogging down. Does anyone one else getting this?
My MX-3 Website
My MX-3 Website
