Intake Support
Intake Support
Hello everyone: I've just installed a dragon hyper intake system on my 92 MX-3 The installation was easy. Horsepower seem greater. But It really didn't help make the can any louder which is what I was expecting The airflow sensor restricts the amount of air coming into the engine. So is there anything I can do to make the intake louder on acceleration. Madjeep
Re: Intake Support
you can have a little port and polishing done or install an exhaust. other than that, maybe a turbo
SOLD - 93 GS Custom intake, exhaust, phenolic spacers, port matching, front upper strut bar, 17" wheels, dragon body graphics, black/white interior, sound system, tints, altezza tails & 3rd brake altezza, g-force front
'94 Caprice - rolling fast and low on 20's along with some custom goodies
'86 Regal - Hydraulics, custom wheels, custom paint, shaved, phantom top, leather, power, and lots of chrome
'92 - New import project in the works, should be out in '09
Re: Intake Support
I went with the Hyper intake and it growls when I open up the throttle. It might just be the dragon intake produces less noise.
Re: Intake Support
Anyone know how much porting, polishing, boring or stroking an engine would cost (KL-DE 2.5L)
93 GS, KLZE, KL31 ECU, Centerforce Stg 3 Clutch, 2.25" Exhaust w/Flowmaster muffler, OBX Headers, Pheno Spacers, Front & rear X-drilled/slotted Rotors, KVR pads, SS brake & clutch lines, Ractive Filter, H&R Springs, Tokico Blue Struts, 8mm Accel Wires, MSD 6A w/ Blaster 2 Coil, HVAC Indiglo Panel. *Sold*
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
Re: Intake Support
Shop around, how good they are and how quickly is often a factor. Look for local shops and dealers who may have connections.
Re: Intake Support
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Hy300:<BR><STRONG>I went with the Hyper intake and it growls when I open up the throttle. It might just be the dragon intake produces less noise.</STRONG><HR></BLOCKQUOTE><P>Hey can you tell me who you bought your hyper intake from. I'm interested in buying another. Mine is nothing but a filter and a small pipe with rubber boot and clamp. Any advice would be appreciated. Thanks
Re: Intake Support
I bought mine through importstudio.com. It kinda sucks how the v6 gets screwed over with the intake systems. You're better off making your own and putting on your own filter element from whatever brand you want. Check under V6 Faq. The way my intake went together I put the 3" by 3" silicone adaptor over my VAF and clamped it tight, then inserted the aluminum tube snuggly inside that, finally I slid my filter overtop of the aluminum pipe sticking out and clamped that down (down make it too tight as the rubber will rip).<P>I would suggest getting a filter from American Speed Center or maybe an Auto Zone. I'm making a cold air box and I need to attach the pieces together tomorrow and take some pics. That may help your choices too, the metal looks awesome.
