V8 in an MX-3 ????
SmokyMcGee
V8 in an MX-3 ????
This question has boggled my mind for quite some time. If you can fit a Ford V8 5.0 litre engine into a Miata... Is it possible to put one into an MX-3 ???<P>------------------<BR>Edgar Paredes
- Custommx3
- Site Administrator
Re: V8 in an MX-3 ????
1st of all the mx-3 is a FWD car so no. <BR>With enough $$ you can do anything.<BR><P>------------------<BR>Barry Clark<BR><I><B>Moderator</B></I><BR>1995 Mazda Mx-3 RS<BR>Chaste White<BR><A HREF="http://www.barrykclark.com" TARGET=_blank>barrykclark.com</A> <BR> custommx3@usa.net
SmokyMcGee
i totally forgot the miata was rear wheel. foolosh me
yeloboy
hell no what are you thinking.your modifications will tear your frame up. a miata doesnt even have the mass to hold such an engine.you wouldnt need a v8 if you would make that thing a twin turbo. as a mater of fact an rx7 engine would be alot faster than an american v8. try to stay light man.
INFAMOUS YELOBOY
A V8 was put into a MIATA in South Africa I believe - plus it was running a shot of NOS or 7 - I heard it went like stink - I think it pulled consistent 12's on the 1/4 - but why talk about MX-5's when we can talk about MX-3's ??????
'93 MX-3 (Eunos Presso)<BR>Custom Intake<BR>10mm ignition leads<BR>Straight through exhaust (no cats)<BR>Automatic->Manual trans. conversion
SmokyMcGee
V8 Miata's have been done ask a couple of Miata owners if i t can be done. I seen a couple of them sell on eBay.
SmokyMcGee
<A HREF="http://www.monstermotorsports.com/mega1.html" TARGET=_blank>http://www.monstermotorsports.com/mega1.html</A> <P>there ya go<P>------------------<BR>Edgar Paredes
Stevekowalchuk
my buddy's dad brought out a 5.0 miata with 200 shot of nos to the street races this season.
David Coleman
<A HREF="http://www.cardomain.com/member_pages/v ... 651&page=3" TARGET=_blank>Faster than any 5.0 powered miata</A>. Stock block Mazda 4cyls are ridiculously strong.
David Coleman
- millionflame
Well, you CAN change the MX-3 over to a RWD, but it's soo much work that it is almost not worth it. After that, the engine should be small enough for the area, but you will probably have to move a lot to the back, or other places. Although, I'm sure someone is going to contradict everything I say anyways, so you might as well just try it.<P>~A
~ Millionflame (94 GS 120K)
