Now, I realize I tapped to low. I tapped a centemetre below the oil line. but doesn't the oil level drop when the car is running? How bad is it really?
Car is a 1994 mazda mx3 rs, B6 DOHC.
oil pan tapped to low, How bad?
- cjthor
Re: oil pan tapped to low, How bad?
I would weld it up and tap higher. You dont want to have the oil back up and blow out your turbo seals.rsxero wrote:Now, I realize I tapped to low. I tapped a centemetre below the oil line. but doesn't the oil level drop when the car is running? How bad is it really?
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
- mx-3_4evr
I have a B6T oil pan with the oil drain plug for $30+ shipping
- cjthor
Im pretty sure the b6t pan and the mx3 dohc pan are different.
Jarid Perry
they are, IIRC its something to due with the baffeling inside the pan, though the bolt pattern is the same i think.cjthor wrote:Im pretty sure the b6t pan and the mx3 dohc pan are different.
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
93' Rs-t BPT - Sold
- mx-3_4evr
^ yeap B6T no baffle, B6DE baffle. Same bolt pattern
- cjthor
also the b6t pan is deeper and the MX3 pan is more shallow due to using an intermediate pan.
Jarid Perry
