K8 ECU to ZE ECU
- bluebullet
K8 ECU to ZE ECU
i was just wondering if n e one who has done the ZE swap and has the stock K8 ecu in and then switched it for a KL31 or KL36 ecu felt the difference in hp?
- babyblueMX3
well it's not the same..but I went from kl36 to k8 on my turbo ze and man does that k8 ecu runs like crap...
RIP 400whp ZE-T MX-3
- bluebullet
- XxantwawnxX
man i have the ze with the k8 and it runs liek a BEAST..wow cant imagine it with the correct ecu.
- jschrauwen
Read a thread in PT the other day about the PGT/ZE's re-chipping their KL01's and KL07(?) ECU's by one of their BB members with an EPROM that emulates the functionality of a KL31.
