[FS] Stock Part Clean Out!! RS and GS
Thefez
Post by Thefez »
RS Rad - $10
RS A/C Condenser - $5
RS A/C Compressor - $5
Crank window regulars - $10 for bolth
RS Stock Intake - $5
Manual Window Regulators - $20 for both!
K8 Injectors in rails - $5
Manual Window crank handles black - $10
AaronTietje
Re: [FS] After Market, RS, and misc items
Post by AaronTietje »
What's your opinion of the obd2 harness swap? Did you notice any gains from it?
Thefez
Post by Thefez »
Smoother idle and better throttle responce, but dyno felt good over obd-1
Thefez
Post by Thefez »
bump need some cash
Thefez
Re: [FS] Garage Clean Out.
Post by Thefez »
bump need this stuff outta the garage
kulluminati777
Post by kulluminati777 »
When will that OBD II swap be fully for sale? Does it work on a KLZE? Kl31 cams and all or does it not even matter the motor as long as its a KL V6.....
Thefez
Post by Thefez »
kulluminati777 wrote:When will that OBD II swap be fully for sale? Does it work on a KLZE? Kl31 cams and all or does it not even matter the motor as long as its a KL V6.....
It will run any KL, but its specific to a milli so a curved neck mani will have the correct vris points and such..
Thefez
Re: [FS] GC Coilover Sleaves, and stock parts
Post by Thefez »
bumps lets get this stuff sold!!
MrMazda92
Post by MrMazda92 »
If you'll part the GCs, I would take the top hats... My stuff won't work with stock mounts, and I wrecked a camber plate. :(
mx3optidrive
Post by mx3optidrive »
Do the coil overs come with the struts? If so, what brand are they?
Shop 506-577-6708
cell 506-381-3503
email danny@jdracing.ca
Thefez
Post by Thefez »
mx3optidrive wrote:Do the coil overs come with the struts? If so, what brand are they?
struts are not included only pic I had of them..
mitmaks
Post by mitmaks »
Which struts are those anyways?
