[FS] Stock Part Clean Out!! RS and GS
Thefez
RS Rad - $10
RS A/C Condenser - $5
RS A/C Compressor - $5
Crank window regulars - $10 for bolth
RS Stock Intake - $5
Manual Window Regulators - $20 for both!
K8 Injectors in rails - $5
Manual Window crank handles black - $10
- AaronTietje
Re: [FS] After Market, RS, and misc items
What's your opinion of the obd2 harness swap? Did you notice any gains from it?
Thefez
Smoother idle and better throttle responce, but dyno felt good over obd-1
Thefez
bump need some cash
Thefez
Re: [FS] Garage Clean Out.
bump need this stuff outta the garage
- kulluminati777
When will that OBD II swap be fully for sale? Does it work on a KLZE? Kl31 cams and all or does it not even matter the motor as long as its a KL V6.....
Thefez
It will run any KL, but its specific to a milli so a curved neck mani will have the correct vris points and such..kulluminati777 wrote:When will that OBD II swap be fully for sale? Does it work on a KLZE? Kl31 cams and all or does it not even matter the motor as long as its a KL V6.....
Thefez
Re: [FS] GC Coilover Sleaves, and stock parts
bumps lets get this stuff sold!!
- MrMazda92
If you'll part the GCs, I would take the top hats... My stuff won't work with stock mounts, and I wrecked a camber plate.
mx3optidrive
Do the coil overs come with the struts? If so, what brand are they?
Thefez
struts are not included only pic I had of them..mx3optidrive wrote:Do the coil overs come with the struts? If so, what brand are they?
- mitmaks
Which struts are those anyways?
