SS braided brake lines, possible hoax.
- kulluminati777
Re: SS braided brake lines, possible hoax.
oh ok and the subaru brake upgrade u guys speak of is bolt on or will i need more (searched with no results)
Go to pg. 16 of my worklog. It's all there.
- kulluminati777
sweet will do...
- mitmaks
Can you put in millenia booster as well?
- Josh
I looked at the milly booster. the fire wall sits at an angle, completely different than the MX. So the res on the booster is slanted to compensate. I do not think it would work. but then again it may. I have not tried it.
- mitmaks
When changing over to Millenia master cylinder do you leave your pushrod same length or do you have to adjust it?
I believe the pushrods are different lengths. Another key difference is the ports are on the opposite side.
- Josh
push rods are in fact different, but they are different because of the difference in the booster > firewall > to pedal distance. You should be able to use the stock GS Rod. I have it all sitting there I will try and look at it tonight. I have not done so yet as I am trying to find new wheels to finish my brake mod ![Sad :(](./images/smilies/icon_sad.gif)
