Ignition coil signal
A section dedicated to Engine Mangement Systems & Engine Tuning. Megasquirt, SMS, Haltek, ect.
mazpr
Post by mazpr »
To control ignition on a distributor engine/ ignition coil (not coil packs), is it true the signal used is the same one for rpms...?
On my EManage, I want to control the ignition timing
mazpr
Re: Ignition coil signal
Post by mazpr »
bump
Do I get the signal from the ignition coil? or before the ignitetr?
Return to “Engine Electronics/Tuning”
