To control ignition on a distributor engine/ ignition coil (not coil packs), is it true the signal used is the same one for rpms...?
On my EManage, I want to control the ignition timing
Ignition coil signal
Re: Ignition coil signal
bump
Do I get the signal from the ignition coil? or before the ignitetr?
