Exhaust+Electric hybrid turbo
fowljesse
Re: Exhaust+Electric hybrid turbo
Post by fowljesse »
If you could balance it, and have it clutch when the turbo spools, that would be great.
nightfire
Post by nightfire »
fowljesse wrote:If you could balance it, and have it clutch when the turbo spools, that would be great.
Heh... I was thinking that too but clutching at 150,000rpm would be practically impossible. At least for my meagre engineering skills.
I think a sequential electric+gas turbo is the only way this could work.
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
I think a clutched supercharger would be the one that should do that; setup a twin charged system.
It's been said before that power isn't free, that the strain on the electrical system on the motor would possibly neglect any powergain used to drive the motor. Plus for something that would draw that much power, you'd need some extra batteries, which adds to the weight. You could look into capacitors too, but still, once their empty, you still need the charging system to charge them back up.
I'd say do a small non-intercooled clutched supercharger with a small pulley to spool up quick, and at a certain RPM, could even use the MSD window switches, or Megasquirt, have the supercharger disengage when the turbo starts to boost significantly, maybe even a bit of overlap.
Just one thing tho, if you want free electrical power, you may want to look into developping an exhaust (turbo) powered alternator (g/f's idea)
nightfire
Post by nightfire »
Nd4SpdSe wrote:I think a clutched supercharger would be the one that should do that; setup a twin charged system.
Exhaust powered alternator ... hmmm.. that's a good idea. :)
- Gord
nos92mx3
Post by nos92mx3 »
Look into a hybrid
t3/t04 *with a .48 ar or even the borg warner .55 * hell if i can get my 9 pound wastegate to open in neutral at 6k on my 1.6, your 2.5 should have no problem building boost down low.
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
nightfire
Post by nightfire »
I was thinking just a straight t3 .48ar... if I'm reading the turbo calculator graph right i'm dead down the center until I hit my max boost of 10psi.
- Gord
projectzemx3
Post by projectzemx3 »
how are you going to use a electric fan to spin your turbo up faster? you would have to mount the fan in between the turbo and the turbo manifold. <-- hottest part of the car i would say.
if you want low end torque from boost then just get a s/c.
NEED PARTS INSTALLED? PM ME!
nightfire
Post by nightfire »
I was originally thinking of putting a motor in and oversized intake, but this would never work at even 75,000rpm.
I think the only answer would be an electric SC / turbo hybrid where it's a staged system like a sequential twin turbo.
But screw it .. I'm just keeping things simple with a single small turbo. I had considered SC'ing but it's too much work for me, and I want A/C.
- Gord
Return to “Forced Induction”
