m.a.f. before or after the turbo?
oh-hell
Post by oh-hell »
Right now i have it running b4 the turbo at the filter. im not getting enuph sucktion to run my maf so iwas thinking to run it after the turbo. only consern is that im being told by a local sorce that i shouldnt run my intake any larger than 2 1/4in. So if i put it after the turbo the intake will obviously have to be larger. i see the pics of people running it after so whats truly the best way. oh and turbo is brand new.
[fs] 92 MX3 gs 2.5 klze v6, Intake, Exhaust,drop zone spring{awsome},Turbo, Splitfire plugs, fmu, gauges ,drilled slotted rotors ,motegi rims,tires,Blackout lights, and a nut behind the wheel~~ so far.
Bochek
Post by Bochek »
ok that makes NO sence, your not getting enough suction to make your MAF work?
then how does it work on a N/A motor? eh, and if you whernt getting enough "suction" to make it work, then your car wont run.
secondaly SEARCH THE FORUM
http://www.mx-3.com/phpbb2/viewtopic.php?t=51398
geesh,
Bochek
Adam Bochek's 93 1.6L SOHC http://www.bochek.ca/car.gif
cjthor
Post by cjthor »
This subject was just beaten to death last week......
http://www.mx-3.com/phpbb2/viewtopic.ph ... c&&start=0
The MAF MUST be ran like this......
air filter-----MAF----turbo----intercooler----BOV---throttlebody.
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
oh-hell
Post by oh-hell »
ya i red that post and i have seen the pics going the other way. the car will only run right now if you push the plunger down manually wile someone else turns it over. my turbo just isnt sucking enuph air to suck the plunger down. thats why i was aking.
ariesdude
Post by ariesdude »
Not enough suction on a turbo inlet?! The one turbo inlet i had an encounter with - almost sucked my hand into it. Even my N/A DOHC suction is perceptible.
Well are you sure that there are no leaks between the MAF and the turbo? Is this your stock MAF? Have you tried adjusting the MAF? Have you tried another MAF?
94 Mx-3 Precidia
oh-hell
Post by oh-hell »
ya stock maf, also beacuse ok the ze i tryed the probe maf. no air leaks but still no sucky sucky.
cjthor
Post by cjthor »
oh-hell wrote:ya i red that post and i have seen the pics going the other way. the car will only run right now if you push the plunger down manually wile someone else turns it over. my turbo just isnt sucking enuph air to suck the plunger down. thats why i was aking.
what plunger? sounds like you got a vac leak or somethin......
Jarid Perry
Bochek
Post by Bochek »
get a new maf, it sounds like yours is damaged.
Bochek
oh-hell
Post by oh-hell »
stupid me i guess i gotta bad air leak from somewhere. sounds like it coming from the TB but i cant see it , i hope my ze will take the stock de intake manny.
ModMX3 - (Carmaster2005)
Post by ModMX3 - (Carmaster2005) »
One thing i have noticed, and thought about is the tube that runs from the throttle body to the intake. Thats part of the Idle Air Control valve. That you WOULD want to reroute so that it sucks right before the MAF sensor on your turbo setup. Because if you think about it, that small tube (if connected to far after the MAF) wont pull enough air (right after startup) through all the lengh of plumbing to make the MAF adguest the airflow correctly. I noticed this when I installed my cold air intake. I had The Idle Air Control valve tube connected about 4 inchs befor the throttle body and my MAF was about 4 feet after that, It would cause it to almost die right after start up. I would always have to rev it up to get the airflow moving. My Point being That on a turbo setup with the MAF sensor mounted before the turbo you would want that tube (Idle Air Control) mounted Between the Turbo and The MAF, so that your idle will not be affected. This would generally only affect your start up i belive because after a few seconds on startup the IAC adjests in acorrandce with the MAF. Hope this enlightens this subject a bit.
Apexi Safc 2 ,Timex Boost-Temp-Oil Gauges, Stage 1 Performance clutch, 8.5 mm Magnacore plug Wires,2.5 inch exhaust, Cold Air Intake , Short Shifter , High temp rotors & Ceramic pads to slow it all down !
oh-hell
Post by oh-hell »
good point, i think ill look that over. hopefully ill find my vaccume leak at the same time. to bad its so freakin hard to find a TB gasket id sure like to try a fue ideas that gave me. oh anyone hear of a cork or plastic IM gasket that would be good for a turbo ze?
cjthor
Post by cjthor »
oh-hell wrote:good point, i think ill look that over. hopefully ill find my vaccume leak at the same time. to bad its so freakin hard to find a TB gasket id sure like to try a fue ideas that gave me. oh anyone hear of a cork or plastic IM gasket that would be good for a turbo ze?
Id get a gasket from the dealer. whit a boosted car you probbaly want to stick with the metal one.
Jarid Perry
Return to “Forced Induction”
