Water water everywhere!
Guys I have a leak that driving me nuts! I sealed the windsheild. New seals on the side. and I still getting water on the floor in back on the passanger side. I'm also getting a leak from the seatbelt rail on the passanger side. I figure it is from the sunroof. But where is the drain hole up there??<p>Thanks in advance.<p>great site!<p>Jumbie
- Custommx3
- Site Administrator
Re: Water water everywhere!
Please post ONLY once and in the proper forum.
- guyaverage
More than likely your sunroof drain hose has let go and is letting water flow inside the shell of the car down into the back instead of routing it down and out. Go to the on-line shop manual and go to page of S-053 and S-055 (in the 'body' section) , it gives a good view of what I'm talking about. Its surgery, but it shouldnt be that bad. I had the same problem a few years ago. A bunch of dead bugs, dirt, pieces of leaves, etc. flowed down the tube and into the wheel well. Then when it rained the water soaked everything, the dead bug bodies, leaves and crud held the water, and over time corroded a big old rust hole in the metal behind the rear wheel. That was a mess.
-Tim Allen
-Tim Allen
