(Cost Does not include shipping - Prices Negotiable)
V6 MX-3 Special Edition
Spent close to ten g's in parts fixing this car time to let it go
Modifications and Work done:
- KSport Kontrol Pro II Variable height and suspension coilovers (2 years old) - $650
Engine has 180,000 miles on it -{K8, Comes w/ Clutch} ($350)
Clutch - Installed at 161,000 mileage
Transaxle- 130,000 miles 20,000 With this Motor ($250)
Aluminum Alloy Wheels w/ Tires ($35 Ea)
Intake Manifold ($30)
Cold Air Intake ($50)
Brand new bearings all the way around
New Used CV Axles ($100 as set)
Lateral Links in Rear ($30)
Control Arms ($25 Ea)
Calipers Brand New Used all the way around ($35 Ea)
New Used Tires in Rear Michellins in Front
HEI MSD Blaster II External Coil w/ Module ($90)
Brand New Starter ($120)
New Used Shift Control Rod ($20)
New Used trans carrier bushings
New Used Radiator/Thermostat ($40)
Belts ($10 ea)
Proportioning Valve - $45
Master Cylinder - $20
Aftermarket Glasspack Muffler -$30
EGT $15 Ea
L & R Heads ($150)
New Used Planted Seat Brackets ($115 Ea)
Extra Used White Rear Bumper ($65) Will post photo later
2 Owner Vehicle
Hood and driver headlight beyond repair
Chasis beyond repair
If you want to purchase car as a whole it's $1000
Located in North San Diego County, CA
