painted matte black cluster shroud $20
GTR Drive train $150 ***WlLL NOT SHIP***(shipping cost is over $500 plus)
MX3 bumper and reinforced lip $50 (lip is the same price if you want just the lip and hardware)
Magnaflow 2.5" exhaust $100
EBC front brakes, spindle, caliper(600 kms on brakes) $250
rear complete spindle $20 pair
corksport SS brake lines (fits RS not GS) SOLD
Corksport braided clutch line SOLD
rear washer fluid tanks $5 each
push button heater controls $15
GTR front turn signals with harness $40 pair
GTR plastic head lights $40 pair
manual 323 rack tie rods have 6000kms SOLD
B&M short shifter SOLD
corksport bushings with my modified bolt to remove play in shift SOLD
ZX2 trailing arms with energy bushings SOLD
radio shroud $15
under dash cover with switches $20
arm rest SOLD
shifter plastic (shifter boot is from a newer protege) $20
Rear speaker covers $20 pair
rear truck caps with tabs intact SOLD
RS spoiler mounting bolts intact $100
VHT red tinted stock tail lights SOLD
KYB GR2 struts, Eibach lowering springs, moog strut mounts and boots (6000kms) $450 set
corksport GTR down pipe wrapped in DEI wrap, also been welded to go straight back for FWD cars SOLD
BP intake bracket $5
323 GTR tow hook $40
BP front and rear filled mounts SOLD
Stock GTR DP SOLD
GTR heat shields SOLD
GTR driver window switch $30
GTR JDM inside fuse cover $15
GTR eco and AC switch $15
BP ignitors $5 each
B6 and BP coils $15 each
SRD rear tie bar SOLD
power mirrors (not power folding) $30 pair
cusco strut bar $40
SS mx3 door sills $100 FIRM
corsport V2 strut bars front and rear with modified seat bracket SOLD
GTR ECU and relay $275
AC delete tube $15
manual speedo cables $15 each
side markers $5 a pair
chrome door handles $35 a pair
protege steering wheel and air bag $40
GTR VJ23 turbo and manifold (trimmed off heat shield mounts and ceramic coated in a titanium color, also comes with plate to fit FWD) SOLD
grimmspeed manual boost controller $50
VJ20 turbo *needs rebuild* $40
BP 83.5mm piston, new hasting rings and gtx rods SOLD
universal cup holder and tray $15
bp gtx intake manifold $45
miata water pump (doesnt have one of the threaded pulleys) $25
manual cluster (rolled back and now sits at 6668kms) $50
323 GTR cluster at 192740kms $60
mazdaspeed belt covers $10
