Alright, I'll have a look/clean it up as best I can. Thanks!Inodoro Pereyra wrote:There's only one electric motor that does everything. You probably have either a lubrication problem, dirt/rust jamming something, or something worn out.
You will have to take off the roof lining, to then be able to see the mechanism and troubleshoot it, and eventually take it off the car, if needed.
Let's say the sunroof system on the mx-3 was not Mazda's brightest idea...
