No brake peddle pressure
WhiteFinish
Post by WhiteFinish »
hi Guys,
My mx3 has been completely taken apart and now I'm in the final stage of rebuilding it.
Problem: I can't get any pressure for my brakes.
- Car runs ok.
I switched the original front calipers to Mazdaspeed 6 calipers
The rears are switched for Mx5 NB-sport calipers.
The brake lines are goodridge
The mastercilinder is original
The car has ABS
When bleeding the brakes, there is no more air coming out of the lines. Yet, still no pressure.
Who can help me? Where should i start looking, what can be possible problems?
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
RogueWolf
Re: No brake peddle pressure
Post by RogueWolf »
I assume that the fluid levels in the brake master cylinder are all topped up and good?
Have you checked the linkage between the brake pedal and the master cylinder?
WhiteFinish
Yes, fluid is topped of.
What do you mean by checking the linkage? What is there to check?
Worklog click
