things im buying
cold air intake:
http://www.ebay.com/itm/BLUE-FORD-PROBE ... ef&vxp=mtr (getting it so its easier to make a hole for the spray before the t-body
nos kit:
http://www.ebay.com/itm/IMPORT-NITROUS- ... 2ea1798c3d
adapter to get fuel from before the fuel rail.
Fuel regulator, what do I get? Or do I even need one? currently I have the k8 one
To do list:
1.) install cold air intake,
2.) install bottle and run lines up to the engine bay
3.)change STOCK fuel pressure regulator (I have the same one for the k8) what do I get ? one from a 2.5 probe at a wreckers im assuming or a adjustable one?
4.)tap in the fuel.. maybe use the banjo bolt that comes with fuel pressure gauges? to get to fuel from the rails?
5.) make hole for the spray tip and install it pointing towards t-body
6.) do wiring, and connect the switch to the TPS
7.)attach spray and fuel line to the 50shot nos tip : )
( im not planning on doing a fuel pump im sure I will be fine with just 50 shot ) but please let me know if you know if you also think it is safe.
how much power do you guys think 50shot will get me with the klze??
did I miss anything?
if you didn't notice im not sure about-
1.) what to buy for tapping into the fuel line
2.)what I should do about the fuel regulator
