[FS] 93 ZE Parts Car
92StockMx3
Post by 92StockMx3 »
Selling the car as a whole.
Bought the car a while back with the intent on fixing it up but lost interest. When purchased the car was burning a good amount of oil and smoking so figure its the rings that need to be replaced. Drove the car for a few hundred miles until winter. After Winter i went to start it up and apparently an animal chewed the gas line causing gas to spray all over the engine. The car has sat since.
The body of the car is solid very little rust.
It does have 2 flat tires.
At this time the items i know are on the car that may be of interest are:
ECU: KL36
MAF: JE50
Short Shifter
Newer Alternator
Newer Clutch
If there is any interest i will check more things out and get any information that is needed.
Looking for $700 Located in Moscow, Pennsylvania
Mike
1992 Krylon White Mazda MX-3 RS. Cold Air Intake,17 inch Voxx rims with Toyo Proxez 4, Black Projectors, Black Taillights,Smoked Turn Signals.
1993 Brilliant Black Mazada MX-3 GS. KLZE, Short Shifter,
