[WTB] Door Hinges & pin kit
- mazdaspeed23
looking to buy a door hinges & pin kit. cant find it anywhere expect mazda and they want $300.00
Own
1994 MX-3 GS swapped ZE
1994 MX-3 GS Swapped ZE (Gone)
1996 Dodge Dakota Sport v8 Magnum
2007 Ford Fusion SE
WORK LOG: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=81232
My MX-3 is nothing without me, and i am nothing without my MX-3
2007 Ford Fusion SE
Re: [WTB] Door Hinges & pin kit
so... $200.00 sounds like a pretty good deal?
If you do not find a set soon, I will be parting out my car in the next few weeks and can make these available for 30+ship. Or 200. That sounds better.
- mitmaks
Unfortunately on our cars there are no replacement pin/bushings. You must replace entire assembly or you can adapt a pin/bushing from another car.
Ok so why can't you buy bushings, drill the holes in the hinges out to size press the bushings in then pick up SS bolts to finish the mod off. Give me the approx dimensions and I'll see if I have any bushings that'll work.
- mitmaks
That's is exactly what you can do besides replacing entire hinge.Daninski wrote:Ok so why can't you buy bushings, drill the holes in the hinges out to size press the bushings in then pick up SS bolts to finish the mod off. Give me the approx dimensions and I'll see if I have any bushings that'll work.
I've already got the doors pulled off my car, the pins & hinges are yours if you want them.
