I don't remember when this has started.. but whats going on is before I go to start my car I have to give 1/6 throttle before turning the key.. if I don't touch the throttle, it would crank till the battery would die and the car wouldent turn over. (PS the battery is brand new and a AGM) I usually have to hold the throttle for about 2-3 seconds after she turns over or it will stall out, but after all this she idles perfect.....WTF!!! so today I put the mx3 in diagnostic mode and re set my tps, and re set my idle. I got er running mint and thought it would be a good idea to test it from a cold start. I left it it outside (I get the garage
and waited for 2 hours and went out and started cranking it. (cranking with no throttle) CRANKCRANKCRANKCRANKCRANKCRANKCRANKCRANK.... wont turn over.
then I tried with 1/6 throttle. CRANKCRANKCRANKSPURCRANKCRANKCRANKSPURCRANK... then tried a little more throttle than usual and it went and then she actually turned over, then idled perfectly... I don't get it man
I have new plugs 20,000k ago, new wires 2000k ago, disty cap and rotor 2000k ago.
thanks!
