Brighter turn signal bulbs
- mitmaks
Does anyone if they make brighter turn signal bulbs for our signal lights? Maybe LEDs that would fit there?
youdirtyfox
Re: Brighter turn signal bulbs
What size bulb is it? We don't have those turn signals here so I am unsure at the mo
if they can be replaced with LED's, you will have to fit load resistors inline otherwise the
will flash too fast fyi.
- Ryan
I'm pretty sure you can buy plug n play LED bulbs that have the correct resistance built in. They're just decently expensive, like $5-15 ea.
- mitmaks
Bulb is supposed to be 1157
