(FS) MegaSquirt 2 Standalone ECU
- Murdastylez15
Hi, I was hoping to place this in the For Sale section but was unable to find a link to post a new topic there. So I've placed this item on ebay and here is the link if you're interested.
http://my.ebay.com/ws/eBayISAPI.dll?MyE ... =1&guest=1
Thanks!
Thanks!
Dying to be TURBO CHARGED
RobMinhas
Re: (FS) MegaSquirt 2 Standalone ECU
I think your link is only visible to you since it's linked through your "my ebay". I can't get to it, just tells me to log in.
- Murdastylez15
Too bad its not for the V6. Id buy this from you right now.
EDIT- Looks like I can make this work for the v6. Waiting on a email back from Stratisfied.
1993 Mazda Mx-3 GS-Sold
1992 GS "The Bucket" Gone.
92 GS 5spd for sale! Sold it....after I got a hatch cover in great condition
MY WORKLOG, check it out
viewtopic.php?f=46&t=79959
- Murdastylez15
Definitely hit me if you are able to use this.
Thanks.
Thanks.
would this work for a mx3 96 obd2? KLZE?
and this is all I would need to tune my car?
Your OBD2 ECU is a four plug where as 95-92 has three plugs so unless you find a 4 to 3 wiring harness I doubt this would work for you.Tfries-cc wrote:would this work for a mx3 96 obd2? KLZE?
- Murdastylez15
Correct! You may not have much of an issue with finding another harness for your car. As far as splicing and rewiring this ecu with that harness so that it works correctly, may be challenging...or maybe not. Not sure. But if wired correctly it will work.Daninski wrote:Your OBD2 ECU is a four plug where as 95-92 has three plugs so unless you find a 4 to 3 wiring harness I doubt this would work for you.Tfries-cc wrote:would this work for a mx3 96 obd2? KLZE?
- Murdastylez15
RobMinhas
