No speedo or odometer !!
Hey every one I have 1995 with a klze and I have no speedo or odometer just wondering what could be causing this any help is great !!
- Inodoro Pereyra
Re: No speedo or odometer !!
You got 3 things to check: the sensor (on top of the tranny), the cable, or the gauge. Depending on the system being mechanical or electrical you will find different parts (duh!). First, being that you have a ZE, see if the cable is connected. If it's not, make sure the system is complete (that you don't have, for example, a mechanical sending unit and an electrical cable and gauge). If everything seems in order, report back and we'll take it from there.
Diogenes of Sinope.
Diogenes of Sinope.
