[FS] Mx-3 parts - lots of inventory - MUST LOOK!
jaydog is back
UPDATE -
All parts in U.S$$
1.8 BP DOHC engine parts
These were run in my previous engine that had a ring failure. All parts were cleaned and inspected for damage and wear. They are all in like new condition, ready to be re-assembled in and 1.8 BP cyl head. Estimated miles - less than 3000.
Supertech 1mm oversize valves - brand new valves not installed - did open 2 packages - $200
Supertech titanium retainers, springs, and seats. Cotters (keepers) come with them - $280
Carrillo H beam connecting rods - $400
1 micro polished, BP 22mm long nose crankshaft - $200
1 BP throttle body 90-94 - $50
1 BP throttle body 95+ - $50
BP-T oil pan - $50
BP-T intake manifold BP26 - $50
BP-T cams BP26 with lifters - $75
various other BP engine parts - valve covers, brackets etc.. ask me
1.6 B6 engine parts 94-95
94 B6 DOHC flywheel - $50
A/C components for 94 DOHC 4 cyl - inquire
MISC parts -
RC engineering 550cc injectors - SOLD
Set of 4 15x7 multispoke wheels mounted on 205/50/15 Kumho V710 race tires - $200
spare 2 tires - same Kumho V710's - $50
rear cargo cover from my car - $50
stainless scuff guards (side sills) for Mx-3. SOLD
left and right front O.E. fenders BLACk color - $80
various gauge clusters for V-6 and 4 cyl - diff miles on them - pic upon request - $25 each
O.E taillights and Alteza lights - $30 for each pair - Alteza lights SOLD
Parting out 92 V-6 GS
window motor/regulators for power windows, left and right - $30 each
V-6 engine wire harness - $50
KL31 ECU - SOLD
KLZE 31 cams - SOLD Still have cyl heads
KLZE intake manifold - $40
KL light weight aluminum flywheel with Clutchmasters clutch and pressure plate - SOLD
KLZE underdrive crank pulley - $40
V-6 power steering pump - $25
V-6 engine mounts - $40
KLZE throttle body - $50
K8 V-6 transaxle - $300 - shipping may be around $100 - trans has over 150k but is in working order
V-6 axles and intermediate shaft - $25 each for axles - $30 for interm. shaft
rear rotors for Mx-3 Brembo new - SOLD
Hot Shot headers for V-6 - I DO HAVE GASKETS, no bolts or nuts - $75
Mx-3 GS power steering rack $60
NEW LISTINGS -
Master power window switch - $86 - Shipped
V-6 starter - $80
UPDATED 8/6/13
All parts in U.S$$
BP-T oil pan - $50
MISC parts -
KL31 ECU - SOLD
NEW LISTINGS -
V-6 starter - $80
UPDATED 8/6/13
Last edited by jaydog is back on August 6th, 2013, 9:29 am, edited 2 times in total.
RobMinhas
Re: [FS] Mx-3 parts - lots of inventory - MUST LOOK!
Dibs on those SS sills.
Also, have you got a BP g series mechanical speedo gear and cable?
And are they just the regular Protege BP VCs?
- Surgeonasst222
Dibsjaydog is back wrote:
rear hatch shade from my car - $50 - pics upon request
stainless scuff guards (side sills) for Mx-3. These are O.E in fair condition - $30 - pics upon request
O.E Alteza lights - $30 for each pair
rear rotors for Mx-3 Brembo new - $30
Pm'ed
Kegan
Mazda3 2012 - my NEW DD
Mazda MX-3 RS 1992 - my project
Ford Focus SE 2010 - sold
Ford Focus SE 2003 - sold
Mazda MX-3 RS 1994 - sold
RobMinhas
Would also like a 92-93RS gauge cluster if you've got one.
- Surgeonasst222
RobMinhas wrote:Dibs on those SS sills.
Dammit rob! 2 min before me!!!
Fine dibs on the rest of what I said.... Grrrr
- kulluminati777
ill take the KL31 ECU and are the hot shot headers already good to bolt up or do you have to chop and mod anything?
- mx3_ryder
Looking for both inner front plastic fender shrouds in good condition and rear license plate/marker light assy/harness ?
jaydog is back
I am getting swamped with E-mails guys. I will get to everybody asap.
I don't have the inner fender liners. I do have the rear taillight section harness from a 92 GS that I am parting out though. $20 and you can have it.
- AaronTietje
Are these injectors a "drop-in" for the BP??? I'll be going megasquirt, so wiring them up wouldn't be a problem.
jaydog is back
Mx-3_Ryder, I do have the inner fender liners from the GS I have. sorry about that.
Definitely. The harness to the injectors will have to be Mistu style or an older Honda type connectors for these injectors.AaronTietje wrote:Are these injectors a "drop-in" for the BP??? I'll be going megasquirt, so wiring them up wouldn't be a problem.
Thefez
KL light weight aluminum flywheel with Clutchmasters clutch and pressure plate - $150
interested in these, i realize the sills have been spoken for but if they back out I have cash in hand. pm as well
- Surgeonasst222
FYI spoke for the hatch shade yesterday... Sry fez
- MrMazda92
jaydog is back
You will have to move the cat-con back a little so there is modification to the exhaust, however I do have a cat-back exhaust made for a V-6 Mx-3 that is on my 92 GS...kulluminati777 wrote:ill take the KL31 ECU and are the hot shot headers already good to bolt up or do you have to chop and mod anything?
The Hotshots were originally made for Probes and Mx-6's as you may know.
- tehbrookzorz
