The engine harness was swapped to an escort gt/bp harness.
Running a GTX ecu and turbo.
For whatever reason there is no fuel..... The pump is good (pulled straight from a running car) but it won't run when the pins are jumped in the diagnostic box.
Also, the FP relay was swapped.
Even put in the escort gt ecu.
What else should I check to get fuel???
