Hey guys,
This 94 Rs i have has a bit of a misfire, seems like it's not running quite right, the previous owners said they just changed the plugs and wires, i just replaced the distributor rotor, the parts store didn't have a cap, so i'll have to wait a few days to try that. In my searching I read that it may be dirty injectors. would the ones off the BP or sohc b6 work? any other thoughts as to what would cause a misfire?
thanks in advance,
Dustin
94 1.6 misfire, have a spare BP and sohc b6, what swaps?
- Dustinlib
1994 MX-3 RS, 2004 Mazdaspeed MX-5, 1993 323, 1987 B2000, 1983 Jeep Cherokee
- AaronTietje
Re: 94 1.6 misfire, have a spare BP and sohc b6, what swaps?
Things to try/check
Distributor as a whole
(I can't remember if the 94 has a coil pack but if it does try that)
MAF
make sure the plug wires are seated correctly against the disty and plug
Check for an air leak after your MAF
I would also confirm the new plugs..........it could even be a bad gap in the plug.
As always I would start with the cheapest things first.
MAF
- MazdaMan1991
also it might be a safe call to replace the circular coil thats inside the dizzy, also check your timing
My Mazdas
2008 Mazda 3 FS auto - Totaled
1994 Mazda 626 KL 5 spd - sold
2002 Mazda Millenia S - sold
1994 Mazda MX-3 RS 5 spd - bp swapped
My Worklog/Build Thread
My YouTube Page
My YouTube Page
- Dustinlib
after some investigation i found the #3 spark plug was oily, according to my shop manual this indicates either bad rings, or a leaking valve seal.
