Dead MX3??
FuelInject225
Dead MX3??
Post by FuelInject225 »
Ok so I have a small problem. I have a 1993 1.6l sohc mx3. It overheated and killed and now it won't crank again. Has plenty of gas and its getting spark but all it does is turn over. Any ideas? Anything at all is greatly appreciated. Also it has 237k miles on the motor. Just got an oil change right before this happened.
kulluminati777
Re: Dead MX3??
Post by kulluminati777 »
237 miles!?!?! Whens the last time you change your water pump.....
FuelInject225
Re: Dead MX3??
I havnt changed it since I bought it. Which I bought it with 200k. But I don't see how the water pump would keep it from cranking. My girlfriends eclipse has a bad water pump and it still cranks right up. It'll overheat in a minute but it still runs.
mitmaks
Re: Dead MX3??
Post by mitmaks »
Were spark plugs wet with gas when you took them out? How does oil, coolant look like?
FuelInject225
Re: Dead MX3??
I'm not sure... My girlfriend let some Mississippi rednecks try to fix it before I could go get it and tow it home. I know when I pulled the plugs out one had the tip broke off. And they all had like a brownish red tint on the white right above the threads. But she also said they tried spraying starter fluid in it so i can only assume they sprayed it into the plugs. As for the oil I havnt checked it since it was literally just changed. Maybe 150 miles on it total. But I turned the key to listen for the humming of the fuel pump and there is none. Even took the cover off and put my ear right on it. So i can only assume the pump kicked the.bucket or a relay did.
kakarot135
Re: Dead MX3??
Post by kakarot135 »
Did anyone mess with the maf, that ended up being the issue with mine after the transmission swap
Kakarot 135
FuelInject225
Re: Dead MX3??
The maf could keep it from cranking? I know it'll run hella bad when they go bad but ill have to look into that.
FuelInject225
Re: Dead MX3??
Ok so. Does anyone know if any other year/model cars share the same relays as a 93 mx3? I went to autozone to replace mine and they don't have and they cant even get them. Id like to replace the fuel pump relay before I go spend $150 on a new fuel pump.
mazdaspeed23
Re: Dead MX3??
Post by mazdaspeed23 »
do a fuel pressure test before you go buy a pump. if your hold pressure and line pressure is correct, then your pump is working
Own
1994 MX-3 GS swapped ZE
1994 MX-3 GS Swapped ZE (Gone)
1996 Dodge Dakota Sport v8 Magnum
2007 Ford Fusion SE
WORK LOG: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=81232
My MX-3 is nothing without me, and i am nothing without my MX-3
