Megasquirt 2 install on BP questions.
A section dedicated to Engine Mangement Systems & Engine Tuning. Megasquirt, SMS, Haltek, ect.
Demonic1
Post by Demonic1 »
So, I'm building a MegaSquirt 2 for my car. I bought the DIY kit from them and I'm SO LOST...
I'll be using this for reference.
http://www.megamanual.com/ms2/V3assemble.htm
Step #22
For the "optional" component... Do I install the circuit for the IAC Stepper motor? I don't know if my BP05 uses one or not. Which relates to step #62 I skipped the PWM Idle valve component. I'd swear I don't need that.
Step #50 I installed The Hall/Optical input circuit (#50.a) I did not install the "Coil negative terminal/points" (#50.b). I did not install the jumper to select between them. I also skipped step #51 since it implied that if I was using a Hall circuit I didn't need that.
Step #65 I didn't know which option to choose. I believe I'm using the "Direct Coil Control" and should install the high current ignition driver? And run the steps on this page? http://www.megamanual.com/ms2/vb921.htm
I thought the MS2-extra board was a completely different set of hardware, but from what I've read it's an upgraded build of the base. Since I want to be able to use dual fuel maps, I believe I'd need to build it as a MS2-extra? As far as I can tell in the MS2-Extra conversion manual, I just need to run a wire from "S12c to JS9". That and install the firmware for it...
But then again if I can run switchable fuel tables from the plain MS2, I guess this is moot. Can I?
The setup for putting a hardware switched input for "Table switching" says to build a circuit and install it on the underside of the board. I assume I can build this in the "proto" section and run leads to the points. I'm a bit confused by the setup though. http://www.msextra.com/doc/ms2extra/MS2 ... ableswitch
I'll be setting up a CP account shortly and seeing if I can get Lex to help me. He'll be all "Stupid noob" and I'll be lost :) still
92 RS BP05
93 GS KLZE
nolig2278
Re: Megasquirt 2 install on BP questions.
Post by nolig2278 »
I know this is an old thread but I am installing a MicroSquirt on my 94 mx-3 BPT so I am looking for others with similar setups. Just in case we can collaborate.
94 RS to BPT
2.5 FMIC
MicroSquirt
2.5 Exhaust
[url=https://gilon.levinsonltd.com/mx-3.html[/url]
Demonic1
Post by Demonic1 »
I put the whole setup on the back burner, but I was doing the DIY setup and not a PNP microsquirt. I wouldn't know where to start.
92 RS BP05
93 GS KLZE
marcdh
Post by marcdh »
For my 1.5 b5ze I basically built the miata/mx5 build for DIYPNP. My pin out is available at:
http://uk-mx3.com/forum/viewtopic.php?t=6628
Maybe not much use if you're not DIYPNP though.
View Worklog
Return to “Engine Electronics/Tuning”
